java.lang.Exception: No USB Blaster detected. Arria5 Starter Kit Windows 7
Hi Yuanli:
1. Can SOF be programmed with quartus programmer?
Yes, I can program the 2 FPGA's on the start kit board with Quartus. See screenshot.
2. Are you using USB Blaster II? Can you try other USB Blaster II?
As I understand, the USB Blaster II is on the Arria5 Starter board? I am connected to the board via USB, so i dont think there's a way to try an external USB Blaster.
3. Can you check and update the JAVA version to latest?
Yes, I checked, and Java update is run every week automatically, and it was last run on 3/2/2022.
I attached some screenshots:
- Arria5 starter kit board programmed successfully via Quartus
- Error I get when I try to start the BTS Clk Control and power Monitor utilities in windows
- Paths I set in windows for the BTS, Clk Control and Power Monitor Utilities. (I'm using Windows 7 64-bit)
- I can start the BTS, Clk_cont, and PM via Nios2 Command Shell, but no USB Blaster. Even though I can see devices and USB Blaster when running jtagconfig.
