Xiaoxiu
1 year agoIssue with quartus_pgm Command-Line .jic File Programming on DE0-Nano (Ubuntu 24.04 + Quartus Prime
Dear Sir/Madam, I am currently working with your DE0-Nano Development Board (featuring the Cyclone IV E EP4CE22F17C6N FPGA) and attempting to program FPGA configuration files using Intel Quartus Pri...
JohnT_Altera
1 year agoHi,
The reason that it is not working is due to the Serial Flash Loader is not being programmed into the FPGA before programming the flash.
Please run "quartus_pgm -c USB-Blaster -m JTAG -o "PI;/path/to/your_file.jic@1"
Xiaoxiu
1 year agoHey JohnT_Intel,
My bad, sorry for the delay in getting back to you!
Thanks for making it super clear – so the whole problem was indeed that the Serial Flash Loader wasn't getting programmed into the FPGA before the actual flash programming. Got it!
I'm heading straight to my terminal to try that command you gave me: quartus_pgm -c USB-Blaster -m JTAG -o "PI;/path/to/your_file.jic@1". I'll tell you the results real soon!
Really appreciate your help!
