hsaee6
6 years agoIs it possible to use DDR3 without configuring it from the QSYS hardprocessor? I want to use DDR3 for the boot up of the HPS. What should be the steps i need to follow. Thanks.
I want to boot my HPS with out the FPGA support but using the DDR3. How and where to configure the registers of the DDR3 if i dont want to use the configuration of the QSYS. My HPS is connected to ...
HBhat2
Contributor
6 years agoHi,
As per my previous experience,
Although you are not using any logic in the FPGA, you have to use Quartus tool & Qsys. In the QSYS, configure the HPS with required IO muxing & boot source & HPS DDR3 configurations. Then just write a verilog/vhdl top module instantiatin the QSYS system.
Then compile the Quartus project & use the sopcinfo & FPGA binary for generating the HPS binaries like preloader, uboot etc. To generate HPS binaries, I think SOC EDS tool is used.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-a10-soc-boot.pdf - this document talks about HPS boot flow
With Regards,
HPB
