aiedb's avatar
aiedb
2 years ago
invalid module format LKM DE1-SOC
hii i am trying to compile a simple device driver and insert it on lenux system that is on the DE1-SOC board that i have
i included the files when i compile the lkm module gets generated but when i move it to the de1-soc board and try the insmod command i get an error i it cant load
when i do file hello.ko i can see that its elf 32bit arm file
but when i put on the board it says invalid module format
what i missing here i be glad for help
the make file code
Target object file
obj-m := hello.o
Cross-compiler path for ARM (BeagleBone)
CROSS_COMPILE_ARM = arm-linux-gnueabihf-
Cross-compiler path for x86 (Intel)
CROSS_COMPILE_X86 =
Target architecture (default: ARM)
ARCH ?= arm
ifeq ($(ARCH),x86_64)
# Compile for x86 (Intel)
CROSS_COMPILE := $(CROSS_COMPILE_X86)
else
# Compile for ARM (default)
CROSS_COMPILE := $(CROSS_COMPILE_ARM)
endif
Kernel directory
KERNELDIR ?= $(HOME)/linux
Current directory
PWD := $(shell pwd)
Build target for building the module
module:
$(MAKE) -C $(KERNELDIR) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) M=$(PWD) modules
@Echo “Building module for $(ARCH) architecture”
Clean target for cleaning the module build artifacts
clean:
$(MAKE) -C $(KERNELDIR) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) M=$(PWD) clean
rm -rf *.o ~ core .depend ..cmd *.ko *.mod.c .tmp_versions
Declare the targets as phony targets
.PHONY: module clean
the lkm modle code
  • $Id: hello.c,v 1.5 2004/10/26 03:32:21 corbet Exp $
    #include <linux/init.h>
    #include <linux/module.h>
static int hello_init(void)
printk(KERN_ALERT “hello world \n”);
printk(KERN_ALERT “module is up \n”);
return 0;
static void hello_exit(void)
printk(KERN_ALERT “bye bye \n”);
printk(KERN_ALERT “module is down \n”);
return ;
module_init(hello_init);
module_exit(hello_exit);
MODULE_LICENSE(“Dual BSD/GPL”);
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
    Back to your issue, for the cycloneV device could you use the cross compiler with CROSS_COMPILE=arm-none-linux-gnueabihf-
    Jingyang, Teh
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Do you have any follow up question on this case?
    Jingyang, Teh
    • aiedb's avatar
      aiedb
      hii no thanks for help
    tehjingy_Altera
    Hi
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    Jingyang, Teh
