dhia91
5 years agoInternal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_region_tight
Hello all,
i describe you my problem :
i work on Cyclone V GX (SoC) and fit on quartus prime 17.1 --> i have a qsys core connected to a nios embedded core which worked up to now.
I only add o...
dhia91
4 years agoHello all,
I re-open this post, because i stil have place and route problem with this error :
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_region_tighten.c, Line: 649
[05:22:45] : [Step 3/6] Internal Error
i tried to add tcl constraint : set_user_option -name CL_REGION_TIGHTEN_V2_ENABLE OFF
but quartus do not recognize it. i have this error :
ERROR: Illegal user option name: CL_REGION_TIGHTEN_V2_ENABLE. Specify a legal user option name. To get a list of legal names, use the "get_all_user_option_names" command
Can anyone help me for that ?
FYI, i use quartus 17.1
Thanks in advance.
