dhia91
5 years agoInternal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_region_tight
Hello all,
i describe you my problem :
i work on Cyclone V GX (SoC) and fit on quartus prime 17.1 --> i have a qsys core connected to a nios embedded core which worked up to now.
I only add o...
SyafieqS
5 years agoDhia,
Noted and glad you manage to solve it.
INI file is quartus setting where you can control the quartus unlike in GUI. You You can view and change user options in the .ini file with the Tcl commands set_user_option and get_user_option in the project Tcl package. The cl_region_tighten_v2_enable=off is is to disable cluster region during compilation.
