dhia91
5 years agoInternal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_region_tight
Hello all,
i describe you my problem :
i work on Cyclone V GX (SoC) and fit on quartus prime 17.1 --> i have a qsys core connected to a nios embedded core which worked up to now.
I only add o...
dhia91
5 years agoHello,
Thank you for your reply (unfortunately too late) I bypassed the problem in usign multi seed compilation and timing correction.
hwat do you mean by " ini "cl_region_tighten_v2_enable=off"?" ==> add tcl constraint with "cl_region_tighten_v2_enable=off"
FYI, i use script compilation...
