dhia91
5 years agoInternal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_region_tight
Hello all,
i describe you my problem :
i work on Cyclone V GX (SoC) and fit on quartus prime 17.1 --> i have a qsys core connected to a nios embedded core which worked up to now.
I only add o...
SyafieqS
5 years agoHi Dhia,
Can you running the compilation with ini "cl_region_tighten_v2_enable=off"?
This should avoid the IE.
