interfacing RTC module to hps driven i2c pins
Hi Snehal
For the RTC Module did you associate it to a kernel driver?
From the starting logs that the rtc is being registered under the kernel.
"[ 1.217136] rtc-ds1307 0-0068: setting system clock to 2000-04-24 05:56:41 UTC (956555801)"
That is why the address is showing UU when you are using the i2cget command.
Regarding the kernel hang, does it happen all the time?
I see that the uboot version is quite an outdate one. I would suggest you to use the latest uboot version(U-Boot 2022.04).
Jingyang, Teh
Hello Jingyang,
Thanks, RTC detect sorted. but not able to read the correct date and time.PFA c code
Kernel hang is still the issue at times, what could be the probable reason.
Also can you help with the example code for RS232 with flow control.
snehal_p
