Aidin-P2D
3 years agoInterfacing Nios II and HMC on Cyclone vGT
Hi everyone,
Hope all well and I appreciate if you take a look at this and see if you can help us. We are using Cyclone V GT Dev board to test DDR3 HMC controller. We used 32 bit SGDMA to write int...
KellyJialin_Goh
3 years agoHi Aidin,
The NIOS II on platform designer should be no issue as you have all your project settings done.
The only down side and limitation is HMC does not support NIOS II with large memory bytes, and soft memory controller is able to support larger memory.
Are you able to proceed with Soft Memory Controller for your project and are you happy with the workaround?
Hope to hear from you.
Thank you.
Best,
Kelly
