Aidin-P2D
3 years agoInterfacing Nios II and HMC on Cyclone vGT
Hi everyone,
Hope all well and I appreciate if you take a look at this and see if you can help us. We are using Cyclone V GT Dev board to test DDR3 HMC controller. We used 32 bit SGDMA to write int...
KellyJialin_Goh
3 years agoHi,
Unfortunately, This Nios® II processor instruction master cannot address more than a 256 MByte span of memory; consequently, providing more than 256 MBytes to run Nios® II software wastes memory resources and causes system ID not found on target at expected base address.
I hope this answers your doubts.
Thank you.
Best,
Kelly
- Aidin-P2D3 years ago
Thanks Kelly,
something is not adding up here . data sheet says 256MB however, Nios and Platform designer see the memory size of 512MB? could this be a problem? see below from platform designer?
Aidin.
