Aidin-P2D
3 years agoInterfacing Nios II and HMC on Cyclone vGT
Hi everyone,
Hope all well and I appreciate if you take a look at this and see if you can help us. We are using Cyclone V GT Dev board to test DDR3 HMC controller. We used 32 bit SGDMA to write int...
KellyJialin_Goh
3 years agoHi,
Seems like the issue lies in the memory larger than 256Mb and causes the DDR3 unable to pass through HMC but able to go through Soft Memory Controller.
I will attach the screenshot on the CV GT user guide on the DDR HMC information for your reference: https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/manual/rm_cvgt_fpga_dev_board.pdf
Thank you.
Kelly
Aidin-P2D
3 years agoThanks Kelly,
something is not adding up here . data sheet says 256MB however, Nios and Platform designer see the memory size of 512MB? could this be a problem? see below from platform designer?
Aidin.
