Aidin-P2D
3 years agoInterfacing Nios II and HMC on Cyclone vGT
Hi everyone,
Hope all well and I appreciate if you take a look at this and see if you can help us. We are using Cyclone V GT Dev board to test DDR3 HMC controller. We used 32 bit SGDMA to write int...
KellyJialin_Goh
3 years agoHi,
You may check out the latest update on the NIOS II processer not able to address memory larger than 256Mb as you stated 400Mb data is verified : https://www.intel.com/content/www/us/en/docs/programmable/683689/current/understand-the-instruction-master-address.html
Do check out on the reference guide of External Memory Interface Volume3 (Chapter 3 on the functional description of HMC) for key points that you may have missed: https://www.intel.com/programmable/technical-pdfs/683841.pdf
Best,
Kelly
