Aidin-P2D
3 years agoInterfacing Nios II and HMC on Cyclone vGT
Hi everyone,
Hope all well and I appreciate if you take a look at this and see if you can help us. We are using Cyclone V GT Dev board to test DDR3 HMC controller. We used 32 bit SGDMA to write int...
KellyJialin_Goh
3 years agoHi Aidin,
Sorry for misunderstanding your question. Got abit caught up with our discussion but as I read through your latest comment that might be the root cause of the issue: "Nios is not functioning when connecting Nios instruction master to HMC" and "Array of 400MB defined and filled with data and verified"
Unfortunately, This Nios® II processor instruction master cannot address more than a 256 MByte span of memory; consequently, providing more than 256 MBytes to run Nios® II software wastes memory resources and causes system ID not found on target at expected base address.
I hope this answers your doubts and sorry for the confusion caused.
Thank you.
Kelly
