Interfacing Nios II and HMC on Cyclone vGT
Any updates from you end whether the workaround provided is useful?
Thank you.
Kelly
- Aidin-P2D3 years ago
Hi Kelly,
I managed to test your suggested workaround and we could get the timing closures by reducing the frequency to 320Mhz and changing speed grade to 8. however, the problem is still there and Nios is not functioning when connecting Nios instruction master to HMC. we did implement on chip memory and nios vectors set to that memory. on BSP editor -linker script we selected .text to be onchip memory and the rest to be fpga_sdram which is HMC. system works fine with no issues. Array of 400MB defined and filled with data and verified. so the question remains why Nios system is unable to boot up/function when instruction master connected to HMC. it appears that connection brings the whole system down. any thoughts ?
thanks and regards,
Aidin.
