Aidin-P2D
3 years agoInterfacing Nios II and HMC on Cyclone vGT
Hi everyone,
Hope all well and I appreciate if you take a look at this and see if you can help us. We are using Cyclone V GT Dev board to test DDR3 HMC controller. We used 32 bit SGDMA to write int...
Aidin-P2D
3 years agoHi Kelly,
Thanks for your reply. yes, I can confirm that we programmed correct .SOF. I am using Q22.1 10/25/2022 Lite edition
Reference system.h , I can also confirm that all values correctly set. refresh connection also done but no luck. when we are checking 'Ignore mismatched system ID & timestamp' fields, it shows a classic error "Downloading ELF Process failed".
please see below system ID properties. interestingly, connected system ID and timestamp not found. I don't understand why connecting Nios II instruction master to HMC, can cause this issue.
I will keep trying different combinations to see if any lucks but any advice greatly appreciated.
Aidin.
Aidin.
