Aidin-P2D
3 years agoInterfacing Nios II and HMC on Cyclone vGT
Hi everyone,
Hope all well and I appreciate if you take a look at this and see if you can help us. We are using Cyclone V GT Dev board to test DDR3 HMC controller. We used 32 bit SGDMA to write int...
KellyJialin_Goh
3 years agoHi,
Thank you for posting in Intel community forum and hope all is well.
Mind if I ask did you managed to programmed the correct sof successfully? Which quartus version are you using?
Would suggest on the following, check on the system.h files in BPS project to ensure system ID peripheral are listed with correct value, followed by regenerating the BSP to see if that helps.
As running the program in hardware, try to refresh the connection under 'Target Connections' tab.
You may also try checking 'Ignore mismatched system ID & timestamp' fields and run to the program to see if that helps.
Hope to hear form you soon.
Best Wishes
Kelly
