Intel Stratix 10 MX Development Kit - Board Test System Issues
- 6 years ago
Hi Deshi,
Thanks for you reply. I actually figured out the problem this morning. It was the USB-Blaster not working as intended. Once I switched to a USB Blaster 2, it started connecting properly.
There were some additional issues with using the BTS to program onto the board and the Quartus 19.1 and 20.2 auto-detect wasn't working properly. Once I got the device chain set up properly in Quartus through using auto detect, adding the BTS sof file to pull up the correct device, then deleting the first auto detect device, it working now and I can program to the board.
Thanks again for your help,
Lars
Hi all
When i tried to install "BoardTestSystem.exe" in windows 10... im getting an error "The application was "unable to start correctly(0x0000007b). Click OK to close the application"... in the other hand the programmer was able to find the JTAG.... could not able to install the BTS... any clue about this error.
thanks
Anand
