Larsgrantz's avatar
Larsgrantz
6 years ago
Intel Stratix 10 MX Development Kit - Board Test System Issues
Hello, I have been having an issue with running the BoardTestSystem.exe. When run, I get the following error: Error when scanning hardware - No devices! Please check your board connection! I f...
  • Larsgrantz's avatar
    Larsgrantz
    6 years ago
    Hi Deshi,
    Thanks for you reply. I actually figured out the problem this morning. It was the USB-Blaster not working as intended. Once I switched to a USB Blaster 2, it started connecting properly.
    There were some additional issues with using the BTS to program onto the board and the Quartus 19.1 and 20.2 auto-detect wasn't working properly. Once I got the device chain set up properly in Quartus through using auto detect, adding the BTS sof file to pull up the correct device, then deleting the first auto detect device, it working now and I can program to the board.
    Thanks again for your help,
    Lars
