Intel Stratix 10 MX Development Kit - Board Test System Issues
- 6 years ago
Hi Deshi,
Thanks for you reply. I actually figured out the problem this morning. It was the USB-Blaster not working as intended. Once I switched to a USB Blaster 2, it started connecting properly.
There were some additional issues with using the BTS to program onto the board and the Quartus 19.1 and 20.2 auto-detect wasn't working properly. Once I got the device chain set up properly in Quartus through using auto detect, adding the BTS sof file to pull up the correct device, then deleting the first auto detect device, it working now and I can program to the board.
Thanks again for your help,
Lars
May I know which Quartus version that you are using ?
- Because board test system only works using the exact Quartus version as mentioned in the dev kit website
Another suggestion is to omit software test system and verify your dev kit using Quartus programmer to program your design sof file successful first.
- Ensure you are using all default jumper setting as per dev kit user manual doc
- Lower down your JTAG frequency to either 16MHz or 6MHz
Then try program any S10 design sof file to check whether it works or not. If it failed then pls screenshot for me what's the failure message shown in Quartus programmer GUI.
dlim
- Larsgrantz6 years ago
Hi Deshi,
Lars
