RubenPadial's avatar
RubenPadial
3 years ago
Intel Arria 10 SoC - HPS Ethernet and FPGA
I need to receive some data with the HPS Ethernet with TCP/IP protocol, process them and share with the FPGA.
Is there any example or AN?
What are the steps to get a program to process the data in the SoC and share with the FPGA?
Thank you in advance.
  • KennyT_altera's avatar
    KennyT_altera
    Kindly take note that they will be some slowness on the first reply due to the public holiday, we will get back to you as soon as possible.
  • Jeet14's avatar
    Jeet14
    Which one you are targeting the baremetal application or Linux or MicroC/OS II ?
    Tiwari
  • Jeet14's avatar
    Jeet14
    In linux you need to write the socket programming to build the TCP/IP application over ethernet for server or client on board.
    It is generic way of writing the linux TCP/IP app. For reference you can refer below link
    https://www.geeksforgeeks.org/tcp-server-client-implementation-in-c/
    For HPS & FPGA data transfer, please refer the below link. Same need to be implemented for Arria 10.
    https://github.com/robertofem/CycloneVSoC-examples/tree/master/Linux-modules/DMA_PL330_LKM_basic
    Tiwari
    • RubenPadial's avatar
      RubenPadial
      Hello @Jeet14,
      Thank you for this information.
      If I'm not wrong, the example you sent me about DMA is to manage data between HPS and FPGA memories once data is received by an Linux client application in the HPS. That's very useful but it will be very helpful if you could give more details about how to build/run the client app for the Arria 10 HPS.
  • Jeet14's avatar
    Jeet14
    Let me know if you have any other query on this matter.
    Tiwari
  • Jeet14's avatar
    Jeet14
    For your reference, you can follow steps as hello world application.
    Add yocto application and compile using meta-bake.py script
    $cd meta-intel-fpga-refdes/
    $mkdir recipe-example
    $mkdir helloworld
    $cd helloworld
    Add the .c & .h files and create the helloworld.bb file in helloworld directory. Snapshot from the helloworld.bb file.
    $nano helloworld.bb
    SUMMARY = "Example hello world" DESCRIPTION = "helloworld in HPS"
    AUTHOR = "Test_engineer"
    LICENSE = "BSD-3-Clause"
    LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/BSD-3-Clause;md5=550794465ba0ec5312d6919e203a55f9"
    inherit systemd pkgconfig
    SRC_URI = "file://helloworld.c"
    S = "${WORKDIR}"
    do_compile() {
    ${CC} ${CFLAGS} ${LDFLAGS} helloworld.c -o helloworld
    do_install() {
    install -d ${D}${bindir}
    install -m 0755 helloworld ${D}${bindir}
    Tiwari
      RubenPadial
      Hello @Jeet14
      Thanks for the information.
      Is EDS needed to create the TCP/IP client application or the application to transfer data from HPS to FPGA memory?
      Is it necessary to create a linux yocto with the custom applications/recipes?
      Is there any detailed guide?
  • Jeet14's avatar
    Jeet14
    You need to use the EDS for creating the preloader or uboot.
    For creating the linux userspace application, you need to use the host linux machine where you need to use the intel cross compiler or yocto application method.
    please refer the create your project with timer example for arria 10. ethernet TCP/IP not availble but you are try the previous links and follow the same steps.
    https://www.intel.in/content/www/in/en/support/programmable/support-resources/design-guidance/linux-developer.html
    https://www.rocketboards.org/foswiki/Documentation/UsingYoctoExtendibleSdkForApplicationDevelopment
    Tiwari
  • Jeet14's avatar
    Jeet14
    Let me know if you have any query on this.
    Tiwari
  • Jeet14's avatar
    Jeet14
    I believe your enqury has been answered. With that, I now transition this thread to community support.
    Thank you.
    Tiwari
