I2C Problem - Cyclone 10 GX dev kit
- 3 years ago
The problem is solved.
The I2C slave device does not allow a read like I was doing. First there should be a write before the read. It has a specific pattern for each operation, concerning if it's a read or write and concerning the register that is accessed.
These details are explained in the datasheet of the I2C external device (TI TCA9534PWR): https://www.ti.com/lit/gpn/tca9534
Hi gbssa,
I wonder if you are able to test the waveform with Oscilloscope.
The SignalTap waveform shows the internal signal. It would be helpful if we can know the exact signal on board both at the FPGA and the I2C slave side. There could be a situation that the signal is not correctly received by the slave, such as board-level transfer issue, I/O Pin issue, and so on.
Thanks & Regards,
Xiaoyan
