I have a cyclone 5 gx starter kit where i am trying to create a hardware that counts number of pulses generated by a source? according to logic count should increase every negative edge by one but actually it increases by 7 or 8.
pulses are generated by a speed encoder that gives one pulse per revolution.
input is taken by GPIO header pin 2 i.e. pin D26 on my FPGA Board
device : 5CGXFC5C6F27C7
cyclone 5 family
code used: i have quoted the part that is counting in bold and italic
module speedcal (
sig,//pulses from encoder
clk,//ref clock 50MHz
out,//speed output
value//counter for verification
//////////IO DECLARATION
input sig;
input clk;
output [15:0] out;
output [15:0] value;
/////////INT/EXT REG/WIRE DECLARATION
wire sig;
wire clk;
wire [15:0] out;
reg [27:0] count;
reg [15:0] value;
reg [15:0] temp;
reg [15:0] track;
reg [15:0] store;
reg check;
/////////MAIN
initial begin
count = 28'hfffffff;
check = 1'b0;
end
//50,00,000 count is 4C4B40
always @ ( posedge clk )
begin:COUNT_TIME
count = count + 28'h0000001;
if( count == 28'h04c4b40 ) begin
count = 28'h0000000;
check = ~check;
track = value;
end
end
always @ ( negedge sig )
begin:DIFFERENCE
value = value + 15'h0001;
end
always @ ( posedge check )
begin:RPMCAL
if( value > temp ) begin
store = value - temp;
temp = value;
end else begin
temp = value;
end
if( track == value ) begin
store = 16'h0000;
end
end
assign out = store * 12'h12c;
endmodule
- Rahul_S_Intel1
Hi VLadw,
I am glad that you could able to find the issue, and also when ever this kind of issue is happening, I am requesting to check signal level first. Because that is the first stage of debugging.
RS
- Rahul_S_Intel1
Hi ,
Code is generic, but do check exact physical data is coming to the GPIO pin
- VLadw
Sir i tested and made sure that the inputs to the pin is a perfect wave and according to your comment i can conclude code is good. so last thing only stays may be when there is no signal on pin it toggles itself so adding a pull-up might work i guess. thanks you very much for clearing my doubts towards the code i am actually new to this and started developing since last few days.
will highlight if found any solution
thank u for the response.
- VLadw
Hi i got the culprit as you said, previously i was testing the output of the speed encoder that was clean but missed to check the output of logic level shifting circuit. i used it as the encoder works for 5v and board accepts only 3.3v on GPIO. after the logic-level shifting circuit because of switching ringings is present. It that stays for a time of 4us before signal stabilizes. I will add a de-bounce circuit to clean that up.
