I have a cyclone 5 gx starter kit where i am trying to create a hardware that counts number of pulses generated by a source? according to logic count should increase every negative edge by one but actually it increases by 7 or 8.
Hi ,
Code is generic, but do check exact physical data is coming to the GPIO pin
- VLadw7 years ago
Sir i tested and made sure that the inputs to the pin is a perfect wave and according to your comment i can conclude code is good. so last thing only stays may be when there is no signal on pin it toggles itself so adding a pull-up might work i guess. thanks you very much for clearing my doubts towards the code i am actually new to this and started developing since last few days.
will highlight if found any solution
thank u for the response.
- VLadw7 years ago
Hi i got the culprit as you said, previously i was testing the output of the speed encoder that was clean but missed to check the output of logic level shifting circuit. i used it as the encoder works for 5v and board accepts only 3.3v on GPIO. after the logic-level shifting circuit because of switching ringings is present. It that stays for a time of 4us before signal stabilizes. I will add a de-bounce circuit to clean that up.
