hps_debug.sof file generation
- 3 years ago
Hi All,
If this occurs to anyone, please note that the work around I have been using is to run this command...
quartus_pfg -c -o hps_path=software/hps_debug/hps_debug.ihex output_files/ghrd_1sx280hu2f50e1vgas.sof output_files/ghrd_1sx280hu2f50e1vgas_hps_debug.sof
Please note that you need the .ihex file I mentioned which can be obtained from the link in the first question on this thread.
James
Hi james57,
After I consulted my team and tried to build the GSRD again I managed to get the ghrd_1sx280hu2f50e1vgas_hps_debug.sof - FPGA SOF
I tried to remove and rebuild everything from zero again and I managed to get that file in the output folders.
my previous attempts might encountered some issue where I may have source the wrong version of tools.
To make it clear, I try to make sure my quartus and nios2_command_shell.sh version used is the same as the GSRD.
Make sure executing all the steps from Setting up Environment & Building the Hardware Design
Do let me know if there is any problems.
Aik Eu
