pinktechs
3 years agoHow to write to and read from fpga flash memory?
I'm trying to store data inside the flash memory which I can read from later. For example, I want to store data such as 0001,0010,0011,0100. However, most resources found is to load the configuration...
FvM
3 years agoHello,
as far as I'm aware of, there's no generic parallel flash controller IP offered by Intel. You need to write your own CFI flash controller from the scratch or reuse existing code, e.g. open source.
Generally you should consider that flash memory isn't well suited for storage of small data elements because whole pages need to be erased before rewriting a data word.
