CAlex
Contributor
3 years agoHow to use on chip memory by HPS baremetal
Hi, it's based on CycloneV soc dev kit, the on chip memory was linked to H2F AXI(128bit wide). So I set the OCMemory as 128 bit and writeable RAM. In the HPS code I setup the FPGA image, openned ...
EBERLAZARE_I_Intel
3 years agoHi,
Can you check this out first?:
Also, what do you mean by no 4? Do you want to have for example, in FPGA user mode and access the OCRAM while it is being accessed by the HPS?
- CAlex3 years ago
Contributor
this OCRAM meant to be the GHRD On Chip Memory II IP.
So basically it is a FPGA IP, my object is let HPS send in a buffer and meanwhlie FPGA continue reading from this Memory.
Reguards.
