snehal_p
Contributor
3 years agoHow to use hps driven I2C pins
Can anyone help me with guidelines to use hps driven I2C pins on DE1SOC board
snehal_p
tehjingy_Altera
3 years agoHi snehal_p
For the DE1-SOC dev kit, I see that the I2C is connected to a multiplexer in which you will need to toggle the HPS_I2C_CONTROL (HPS_GPIO48) to switch between the FPGA owning the i2c or the HPS.
Once the dev kit boots into the linux environment you could try searching for GPIO48 under the /dev directory to toggle the i2c to HPS.
You could refer to the document below section 3.6.5
Jingyang, Teh
