CAlex
Contributor
3 years agoHow to setup a time interrupt on de10 standard using C language
Hi, I'm a rookie of the SoCFPGA and I wanted to use it to build a FSM in HPS. I have already finished building the system design as "User Manu" said and get the hps_0.h header file out. I built my ...
CAlex
Contributor
3 years agoHi,
to make sure we are on the same page,
I attached the kernel module for anyone else want to see what happened on this case.
Reguards.
- CAlex3 years ago
Contributor
The return Error is -22
Which indicate handler is NULL(checked) or IRQ can't be used.
And when I checked the /proc/interrupts , the result is as followed:
But as the DTB on my board shows,there should be at least 3 FPGA interrupts.
When I use linux module to install the irq, it is not relay on DTB right?
