CAlex
Contributor
3 years agoHow to setup a time interrupt on de10 standard using C language
Hi, I'm a rookie of the SoCFPGA and I wanted to use it to build a FSM in HPS. I have already finished building the system design as "User Manu" said and get the hps_0.h header file out. I built my ...
CAlex
Contributor
3 years agoHi,
still trying to understand what happened in the kernel, also I tried to make the KML but there are some part missing on my SD card. The Kernel source can't be found in /usr/src menu and now I'm trying to build another sdcard and hope the source code is in the path I hoped.
I'll update the case when I get some progress.
Thank you for your help.
reguards.
