jkhoo
3 years agoHow to recompile verilog code with slight change in reg value using previous fitter(Place & route)
I have a working compilation with the Fitter (Place & route) generated by Quartus 18.1. When i change a value in a 32bits register
from
assign PROD_VERSION = 32'h0008_0008;
to
assign PROD_VE...
RichardT_altera
3 years agoQuartus is not able to rerun full compilation a design without running fitter.
https://www.intel.com/content/www/us/en/support/programmable/articles/000084189.html
You can design partition and preserve the fitter(final) database, a portion of the design. Instead of the whole design undergo P&R.
https://www.intel.com/content/www/us/en/docs/programmable/683247/19-4/design-partitioning.html
Richard Tan
- jkhoo3 years ago
HI Richard,
Thanks for the guidance, will try out your suggestion.
from JJ
