How to Read/Write L4 Peripheral Slave Bus on S10 SX Device
Hello stanley015,
I’m reviewing your u-boot script attached.
By the way, have you accessed F2H bridge with JTAG Master which is default configuration of S10 SoC GHRD?
Yoshiaki Saito
- Hans_1st4 years ago
Hello Saito,
This is my rest of qsys attached.
I build my project regarding to S10 SoC GHRD named "s10_soc_devkit_ghrd_es.tar.gz" which is downloaded in https://releases.rocketboards.org/release/2019.04/gsrd/s10_gsrd/. From the qysy of s10_soc_devkit_ghrd_es.tar.gz, I actually can see the module of jtg_mst.
However, I delete this module from my qsys because I think it will not effect read/write from f2h_axi_slave to l4 slave peripheral bus. I should add this module back or not and what the function of this module is. Also, what I should do after this module is added back?
Best regards
Anyone can give me more suggestions?
Thanks!
- YoshiakiS_Altera4 years ago
Hello Hans_1st,
I tried "s10_soc_devkit_ghrd_es.tar.gz" on Stratix 10 SoC Devkit ES, and have confirmed to be able to access HPS periphrals such as UART0.
After booting U-boot, I also executed the following commands.
S10 SoC Bridge Configuration
https://rocketboards.org/foswiki/Documentation/S10SoCBridgeConfiguration
Next, we can access to HPS via “JTAG to Avalon Master Bridge Cores” below in jtg_mst.qsys.
Then, the system-console which is located in intelFPGA_pro/19.1/syscon/bin is launched. This is a debugging tool for “JTAG to Avalon Master Bridge Cores”. See below.
Using System Console
https://rocketboards.org/foswiki/Documentation/GSRDQuartusProgrammer
Type a command below to show all path name of JTAG port in the FPGA system.
The 4th path is for accessing F2H bridge.
% get_service_paths master
{/devices/1SX280LN2S(2|1)|1SX280LN3S1|..@2#1-9.3.2#Stratix 10L SoC Dev Kit/(link)/JTAG/(110:132 v1 #0)/phy_0/master}
{/devices/1SX280LN2S(2|1)|1SX280LN3S1|..@2#1-9.3.2#Stratix 10L SoC Dev Kit/(link)/JTAG/(110:132 v1 #1)/phy_1/master}
{/devices/1SX280LN2S(2|1)|1SX280LN3S1|..@2#1-9.3.2#Stratix 10L SoC Dev Kit/(link)/JTAG/(110:132 v1 #2)/phy_2/master}
{/devices/1SX280LN2S(2|1)|1SX280LN3S1|..@2#1-9.3.2#Stratix 10L SoC Dev Kit/(link)/JTAG/(110:132 v1 #3)/phy_3/master} {/devices/1SX280LN2S(2|1)|1SX280LN3S1|..@2#1-9.3.2#Stratix 10L SoC Dev Kit/(link)/JTAG/(110:132 v1 #4)/phy_4/master}
Type a command below to set path to ‘m’ variable.
% set m [ lindex [ get_service_paths master] 4]
Type a command below to open a port
% open_service master $m
Type a command below to read UART registers. You can see UART0.cpr, ucv and ctr which are read-only values.
% master_read_32 $m 0xffc02000 64
0x00000046 0x00000000 0x000000c1 0x00000003 0x00000003 0x00000060 0x00000010 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000046 0x00000000 0x00000000 0x00000000 0x00000006 0x00000000 0x00000000 0x00000000 0x00000001 0x00000000 0x00000000 0x00000001 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00083f32 0x3331352a 0x44570110
Type a command below to close the port
% close_service master $m
Yoshiaki Saito
