How to read from stdin in NIOSII with the small_c_library
whithout the small_c_library checked, i am unable to read from standard input.
unless there's some sort of alt_fopen, how do i read from the standard character streams whithout gets,scanf and fopen?
It seems that with the small c library enabled stdin,stdou and stderr are "preopened" files, so i can interact with them as files whithout opening them, can't find right now exactly where i saw this info.
- AnandRaj_S_Intel
Are you saying that, using normal c libraries you are able to read write but not able to read using small c libraries ?
- If simple console read write ->use alt_printf, alt_putstr, alt_putchar & alt_getchar. Refer table 34 gives you the comparison between libraries https://www.intel.com/content/altera-www/global/en_us/index/documentation/mwh1416947091611.html#mwh1416946791328__ID-356-000027c6 OR
- If Read, write to from FPGA peripherals? use IORD and IOWR functions.
Anand
- LucasM
I haven't been able to test it yet, but knowing which functions to use helps, I've tried alt_scanf() which didn't work. Also I was unaware of the new library documentation, that is a huge help. I will test it ASAP (Monday) and give feedback. Thanks, Lucas M - LucasM
Yes, i am able to read incoming data (from the uart) with the full C library, using:
#include <stdio.h> #include <stdlib.h> FILE * fp; char msg[255]; fp = fopen("/dev/uart_0","r"); if(fp) { fscanf(fp,"%s",msg); }I've tried using the alt library, but it fails with:
home/user/project_name/software/nios_project_name_bsp/HAL/src/alt_getchar.c:67: undefined reference to `getc'//source snippet int alt_getchar(void) { #ifdef ALT_SEMIHOSTING char c; read(STDIN_FILENO,&c,1); return c; #else #ifdef ALT_USE_DIRECT_DRIVERS ALT_DRIVER_READ_EXTERNS(ALT_STDIN_DEV); char c; if (ALT_DRIVER_READ(ALT_STDIN_DEV, &c, 1, alt_fd_list[STDIN_FILENO].fd_flags) <= 0) { return -1; } return c; #else return getchar(); #endif #endif }It seems that the direct device drivers aren't available, and neither is getc.
is it some header missing or something similar?
- LucasM
