Sivakumar_S
3 years agoHow to read differential data in double-datarate mode using differential clock for an RF transceiver
Hi , In my design there is a RF transceiver (with Arria10 SoC), which has differential data which is in double data rate mode. Also the data clock (3.84MHz)and frame clock is of differential mode. ...
FvM
3 years agoYou design the intended logic and connect any IO standard of your choice. Differential IO standards use a single port pin. No need for special IO IP.
