Chandrashekhar_K's avatar
Chandrashekhar_K
2 years ago
How to implement mutual exclusion for critical sections in code?
I have a code, where in the board receives data at a rate of 921600 via uart. This is written into a circular ring buffer in the rx interrupt. The same data is read from the buffer in main in a continuous while loop bytewise. But while reading, the bytes are not as same as the bytes written into the circular buffer. Kindly provide ways to protect the critical sections in the interrupt and main.
  • Hello, @Chandrashekhar_K:
    Thank you for contacting Intel Embedded Community.
    We received your request, we want to address the following question to understand it:
    Could you please confirm if the device related to this situation has been designed by you or a third-party developer? In case it is a third-party device, please let us know the name of the manufacturer and the part number of the device.
    Where do you purchase the device related to your requests?
    We are waiting for your clarification.
    @CarlosAM_INTEL.
  • Hi @CarlosAM_INTEL ,
    I am using Altera Cyclone V SOC Development kit. I have modified the example code provided alongwith namely,
    Altera-SoCFPGA-HardwareLib-16550-CV-ARMCC:
    The interrupt callback function that writes data into the buffer is modified as below:
    volatile unsigned int tail = 0;
    volatile unsigned int head = 0;
    char buffer[ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE];
    void recieveData(ALT_16550_BUFFER_t * buffer1)
    #if ALT_16550_BUFFER_ENABLE_SMP
    /* Signal we are in the RX section. */
    buffer1->isr_rx = true;
    #endif
    ALT_STATUS_CODE status = ALT_E_SUCCESS;
    uint32_t fifo_level_rx;
    uint32_t copy_size;
    if (status == ALT_E_SUCCESS)
    status = alt_16550_fifo_level_get_rx(buffer1->handle, &fifo_level_rx);
    /* Copy the RX FIFO into the RX buffer. */
    // alt_16550_int_disable_rx(buffer.handle);
    // alt_int_global_disable_all();
    // portCPU_IRQ_DISABLE();
    const unsigned int tail_1 = tail;
    const unsigned int head_1 = head;
    // portCPU_IRQ_ENABLE();
    if(head_1 < tail_1) {
    copy_size = stdminul(fifo_level_rx,tail_1 - head_1);
    }else{
    copy_size = stdminul(fifo_level_rx,ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE - head_1);
    alt_16550_fifo_read(buffer1->handle,&(buffer[head_1]), copy_size);
    head = (head_1 + copy_size) % ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE;
    // alt_int_global_enable_all();
    // alt_16550_int_enable_rx(buffer.handle);
    /* Disable RX interrupts if the RX buffer is full. */
    /* if ((tail == 0) && (head == ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE))
    status = alt_16550_int_disable_rx(buffer1->handle);
    The function in main that reads bytes from the buffer is given below:
    char readBuffer() {
    if(tail_1 == head_1) {
    return NULL;
    const char data = rxBuffer.buffer[tail_1];
    tail = (tail_1+1) % ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE;
    // alt_int_global_enable();
    return data;
    #define portCPU_IRQ_DISABLE() \
    __asm volatile ( "CPSID i"); \
    __asm volatile ( "DSB" ); \
    __asm volatile ( "ISB" );
    #define portCPU_IRQ_ENABLE() \
    __asm volatile ( "CPSIE i"); \
    I wish to protect access of tail and head. The interrupt function is receiving the whole data. But when we read from the buffer, some bytes are lost ( almost half).
    • CarlosAM_INTEL's avatar
      CarlosAM_INTEL
      Thanks for your clarification.
      The device mentioned in your previous communication has its support channel.
      We are going to transfer this forum to the proper channel.
      The team in charge of this channel will contact you as soon as possible.
      @CarlosAM_INTEL.
