BThai
8 years agoHow to get a 644 MHz clock on the Arria 10 SoC Dev Kit?
Hello, I’m trying to get the Ethernet 1G/10G MAC example design to run on the Arria 10 SoC dev kit. The document here (https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/ug/ug...
AnandRaj_S_Intel
8 years agoHi Binh,
Yes you are correct, Let me check and update on the issues.
Meanwhile can you try this
- From below link we can use Si5338A programmable oscillator which is having max Freq of 710 MHz.
- Which can used be for getting 644.53125 clock.
- You can use U42 CLK_3Ep & CLK_3En pins.
Hope this helps.
Anand Raj Shankar
