How to force manually in ModelSim one dada bus with value like sin(x)
Hi, I am checking to force manually some data bus like: input[10..0] in MOdelSim like here(by console):
force input[0] 0 0, 10, 10, ...... - repeat 200
force input[1] 0 0, 10, 10, ...... - repeat 200
ecc
There is a way to do it in automatic? I means, there is a way to load some file prewrite and add to console in some how? Or mauve by using some verilog or VHLD script that running when i click the simulation start in modelSIM
In that case, you may create a module for the sine function:
module sine_generator (
input wire clk,
input wire reset,
output reg signed [10:0] sine_out
reg [6:0] index; // 7-bit index for 128 samples
reg signed [10:0] sine_lut [0:127]; // 128-point lookup table
initial begin
// Precompute sine values and load them into the LUT
sine_lut[0] = 0;
sine_lut[1] = 50;
sine_lut[2] = 100;
sine_lut[3] = 150;
sine_lut[4] = 200;
sine_lut[5] = 250;
// ... (continue with the full sine wave values up to 127)
sine_lut[127] = -50;
end
always @(posedge clk or posedge reset) begin
if (reset) begin
index <= 0;
sine_out <= 0;
end else begin
sine_out <= sine_lut[index]; // Output the sine value
index <= index + 1; // Increment index for next sample
end
end
endmodule
- KennyT_altera
You will need to write a testbench for stimulus.
We don't usually offer the code in the forum, but here is some example you can try out:
module testbench; reg [10:0] input_signal; integer i; real pi = 3.14159; real sin_value; initial begin for (i = 0; i < 100; i = i + 1) begin sin_value = $sin(2 * pi * i / 100); // Generate sine wave input_signal = sin_value * ((1 << 10) - 1); // Scale to 11-bit range #10; // Wait 10 time units end end endmodule.
Also, please take a look https://www.youtube.com/watch?v=Dm7Ow4XI22g on how to setup the testbench.
- KennyT_altera
Is there any further question?
- Savino
yes, I tried to work with real value and $sin function but when i try to make systesys the message the the function real and $sin are non supported. If u have some way to fix it will be great.
- KennyT_altera
input wire clk,
input wire reset,
initial begin
sine_lut[0] = 0;
sine_lut[1] = 50;
sine_lut[2] = 100;
sine_lut[3] = 150;
sine_lut[4] = 200;
sine_lut[5] = 250;
end
if (reset) begin
index <= 0;
sine_out <= 0;
end else begin
end
end
endmodule
- Savino
tks a lot for all support
- KennyT_altera
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
