How to change reference clock through clock programming for S10 transceiver for adjusting data rate
- 4 years ago
Just wanted to add a note - now I am able to program the clock properly. Here is the procedure:
(1) Launch Quartus Pro and set HW frequency to 16MHz
(2) Launch ClockControl.exe in NIO II command shell and set the target clock
(3) Close ClockControl (must do) to release JTAG
(4) Program FPGA with a chosen .sof
(5) Launch Transceiver Toolkit.
Thanks to skbeh.
Thank you very much for your help.
Indeed Clockcontrol.exe works well alone, however it does not solve my problem effectively. Here is the dilemma I am encountering:
If I use ClockControl.exe alone, it helps set up new reference clock correctly. However, I will not be able to load qts_sma.sof (I am trying to test transceiver sma ports) and have to quit from ClockControl in order to program FPGA, and the clock gets reset to default value.
Did I run something incorrectly? How should I use Clock Control and load qts_sma.sof properly. I use Transceiver Toolkit under System Console of Quartus Pro v18.1 to test sma ports on S10 Transceiver Development Kit.
Thanks again.
Thanks to skbeh.
