JSu's avatar
JSu
4 years ago
How to change reference clock through clock programming for S10 transceiver for adjusting data rate
May I ask how to change reference clock (Y2 for SMA) on S10 GX transceiver development kit through programming in order to adjust the data rate? Thank you,
  • JSu's avatar
    JSu
    4 years ago
    Just wanted to add a note - now I am able to program the clock properly. Here is the procedure:
    (1) Launch Quartus Pro and set HW frequency to 16MHz
    (2) Launch ClockControl.exe in NIO II command shell and set the target clock
    (3) Close ClockControl (must do) to release JTAG
    (4) Program FPGA with a chosen .sof
    (5) Launch Transceiver Toolkit.
    Thanks to skbeh.
