How do I use PIO which is configured as InOut?
Hi, thanks for your reply. But I am not speaking about the bidirectional setting.
The IOs can be configured as Input, Output, Bidirectional and InOut. The first three ones are self-explanatory for me and are well documented. What I would like to know is the fourth setting InOut. If setting a single IO to InOut, I have access to two IO pins in Quartus, one being fixed input and the other one being fixed output. So I doubt, that I can set the direction for the pin. Instead I would expect, that I can write data for the output pin to the data register and read data from the input pin from another data register. But I can not find out what's the correct address / offset for both data register (offset "0" and bit "1" would be the case for all the other settings Input, Output and Bidirectional).
I hope could point out a problem a bit more. Pleas let me know if I misunderstood something. Thank you in advance and best regards.
