jjian40
7 years agoHello, I have purchased cyclone V GT FPGA development board. I would like to ask whether the HSMC port B interface's transmission and reception pins support LVDS or not? If not, please recommend a ADC which use 1.5-v PCML standard for me.
1 Reply
- AnandRaj_S_Intel
Both HSMC port A and B supports LVDS interface.
You can check DIFFIO_TX_xx & DIFFIO_RX_xx FPGA pin are used by HSMC ports. And which supports true LVDS transmitter & receiver channels on row and column I/O banks. Pins with a "p" suffix carry the positive signal for the differential channel.Pins with an "n" suffix carry the negative signal for the differential channel.
Please refer the pin connection guideline and schematic.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-v/pcg-01014.pdf
Anand
