MK_ABQ
Contributor
4 years agoGeneral question in PLL
A general question in PLL. I am currently working with an Intel IP which has an I/O PLL. The PLL will be locked once the input frequency is stable. At the same time, it says the jitter toler...
- 4 years ago
In PLL simulation you cannot introduce jitter as the simulation model not include the jitter factors. There is requirement you need to follow for supplying clock source/oscillator to the PLL input, this spec already cover jitter and skew to make sure PLL working as expected in datasheet.
regards,
Farabi
AqidAyman_Altera
4 years agoHello,
Thank you for reaching out to Intel FPGA Community.
Could you share which device are you using?
Aqid Ayman
MK_ABQ
Contributor
4 years agoHi,
I am using Arria 10 FPGA. How do I introduce jitter in simulation ?
