General question in PLL
- 4 years ago
In PLL simulation you cannot introduce jitter as the simulation model not include the jitter factors. There is requirement you need to follow for supplying clock source/oscillator to the PLL input, this spec already cover jitter and skew to make sure PLL working as expected in datasheet.
regards,
Farabi
Hello MK_ABQ,
Thank you for posting in Intel Ethernet Communities.
For us to further check the issue, please provide the following details.
- What is the model of the Intel Ethernet network card that you are using?
- Are you designing a board/system with Embedded network card?
- Can you tell us more about this test or project that you are doing for us to assist you or route you to the correct team if needed.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
- MK_ABQ4 years ago
Contributor
Hi Mike,
I am not using an Ethernet IP. I am using a LVDS IP, and interested specifically to understand jitter/PLL behavior. Should I post this question in a different group?
