Abood
4 years agoFPGA .sof file
Hello, after I compile my code, open the programmer, and try to add the .sof file in the output_files folder, I do not see the .sof file. Is there a reason for this? My .sof file is not being generated, can anyone help ASAP please?
- YuanLi_S_Intel
Hi, may i know which quartus license you are using? Also have you seen any error message?
- sstrell
In the Compilation Dashboard (Pro) or Tasks window, do you see the Assembler running? If not, perhaps you've turned off the option to run it as part of a full compilation. You can run it manually from the Processing menu.
If the Assembler is running and you are still not getting a .sof, check the Device and Pin options in Assignments -> Device. Perhaps you've disabled .sof generation.
