nikhl
4 years ago"Found more than one suitable slot" while testing the 10GBE PAC-PAC test
I am testing the PAC -to -PAC Ethernet MAC 10 Gbps link. When i program both the intel Arria 10 GX PAC cards with the same design and executing the host code i am getting the following output...
JohnT_Altera
4 years agoHi,
When you are running "./pac_hssi_e10 -b AF --channel=0 --action=stat" and "./pac_hssi_e10 -b 86 --channel=0 --action=stat", not sure if you are able to select the device correctly? Please try to uncomment the host code. We should expect that you are able to select the specific device rather then showing more than 1 device is detected.
nikhl
4 years agoHi,
I have uncommented those lines the host code. It is giving the "found more than one suitable slot" again.
Also while i am executing using this command "./pac_hssi_e10 -b AF --channel=0 --action=stat" , it is showing invalid bus.
server2@server2:~/inteldevstack/a10_gx_pac_ias_1_2_1_pv/hw/samples/eth_e2e_e10/sw$ ./pac_hssi_e10 -b AF --channel=0 --action=stat invalid bus: AF ./pac_hssi_e10 PAC HSSI configuration utility Usage: pac_hssi_e10 [-h] [-b <bus>] [-d <device>] [-f <function>] [-s Src. MAC] [-m Dest. MAC] [-p Number of packets] [-l Packet length] -a action -h,--help Print this help -b,--bus Set target bus number -d,--device Set target device number -f,--function Set target function number -c,--channel Set HSSI channel (0 - ffffffff) -s,--src_mac Set Source MAC (in the format AA:BB:CC:DD:EE:FF) -m,--dest_mac Set Destination MAC (in the format AA:BB:CC:DD:EE:FF) -p,--packets Total number of packets (in hex format e.g. 0x100) -l,--pkt_len Packet length bytes (in hex format e.g. 0x100) -a,--action Perform action: off Assert MAC resets on Deassert MAC resets stat Print channel statistics stat_clear Clear channel statistics loopback_enable Reset MAC, enable internal channel loopback, send packets, and print stats loopback_disable Reset MAC, disable internal channel loopback, send packets, and print stats pkt_send Send 0x10000 packets server2@server2:~/inteldevstack/a10_gx_pac_ias_1_2_1_pv/hw/samples/eth_e2e_e10/sw$ ./pac_hssi_e10 AF --channel=0 --action=stat Found more than one suitable slot, please be more specific. server2@server2:~/inteldevstack/a10_gx_pac_ias_1_2_1_pv/hw/samples/eth_e2e_e10/sw$ ./pac_hssi_e10 86 --channel=0 --action=stat Found more than one suitable slot, please be more specific.
