nikhl
4 years ago"Found more than one suitable slot" while testing the 10GBE PAC-PAC test
I am testing the PAC -to -PAC Ethernet MAC 10 Gbps link. When i program both the intel Arria 10 GX PAC cards with the same design and executing the host code i am getting the following output...
JohnT_Altera
4 years agoHi,
Which PAC card are you used to send the packet? From the log you should be using 86:00.0 to send the packet then you will need to use AF:00.0 to received the data packet.
Below is how you should be performing. The stat will show 86:00.0 is only transmitting data while AF:00.0 is receiving data.
./pac_hssi_e10 86 00 00 --channel=0 --action=stat_clear
./pac_hssi_e10 86 00 00 --channel=0 --action=pkt_send
./pac_hssi_e10 AF 00 00 --channel=0 --action=stat
John Tio
