nikhl
4 years ago"Found more than one suitable slot" while testing the 10GBE PAC-PAC test
I am testing the PAC -to -PAC Ethernet MAC 10 Gbps link. When i program both the intel Arria 10 GX PAC cards with the same design and executing the host code i am getting the following output...
JohnT_Altera
4 years agoHi,
Can you try "./pac_hssi_e10 -b af -d 00 -f 00 --channel=0 --action=stat"? If you are still facing issue then can you try running "fpgainfo fme"?
nikhl
4 years agoWhen i try to run the "./pac_hssi_e10 -b af -d 00 -f 00 --channel=0 --action=stat" it is saying "invalid bus :AF" but on fpgainfo fme both the PAC cards are showing respectively with the bus number "AF" & "86".
