FLASH_LOADER.qpf not found in I2C_RSU
I am seeing only the MAX10_FLASH.qsys in the I2C_SLAVE folder. I am using the Quartus version 18.1 and I opened the i2c_rsu.par from the below link
https://fpgacloud.intel.com/devstore/platform/17.1std.1/Standard/i2c-remote-system-update-example/
I also put what I am seeing in the below link. If you have a different file can you share it here. Thanks for the support.
HI,
@YuanLi_S_Intel Can you share the Flash_loader.qpf here. It would be very helpful to me.
Ravi
- RVadl25 years ago
I have only the Max10_Flash.qsys file and it is not entire thing. I have the Master part and am waiting for the Flash_loader.qpf slave code to learn about the registers implemented in it.
Ravi
- damonzhu2 years ago
Has your problem been solved? How to find the Max10_FLASH.qsys file? Can you share it with me? Thank you very much!
Damon
