Fitter error of PCIe in A10 GX dev board
- 3 years ago
Hi David,
KDB means Knowledge Base, It is the link provided by you
- Error (175001): The Fitter cannot place 1 HSSI_PMA_TX_CGB, which is... (intel.com)
- As mention it is more related to Native PHY IP (tranceiver), which might not be the error to your problem as you are using standard PCIe design.
Step how to Assigning Pin I/O Standards in the Intel® Quartus® Prime Pin Planner you may refer to the link.
For the correct Pin number, you may refer to the user guide below under Table 5-16 , page 72/103
Hope this is helpful, let me know if further clarification is needed.
Wincent_Intel
Hi wchiah
I guess the problem was because a typo of the highspeed pin name. after I corrected it, there is no error message anymore.
thank you for all the support
David
Hi David,
Glad that your problem solve, Nice to work with you.
Feel free to create a new case if you face any problems in future.
If the case is assigned to me again, I am happy to continue working with you.
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
Wincent_Intel
- dsun013 years ago
Contributor
Hi Wincent
most of the support request is due to the user don't know how to use the tools or device. sometime the requester just don't know where to get the data sheet or the user manual. if you give me a hint where to search for the answer will be 10. if you can tell me which section or your understanding. that will 10+.
thank you,
David
