Fitter error of PCIe in A10 GX dev board
- 3 years ago
Hi David,
KDB means Knowledge Base, It is the link provided by you
- Error (175001): The Fitter cannot place 1 HSSI_PMA_TX_CGB, which is... (intel.com)
- As mention it is more related to Native PHY IP (tranceiver), which might not be the error to your problem as you are using standard PCIe design.
Step how to Assigning Pin I/O Standards in the Intel® Quartus® Prime Pin Planner you may refer to the link.
For the correct Pin number, you may refer to the user guide below under Table 5-16 , page 72/103
Hope this is helpful, let me know if further clarification is needed.
Wincent_Intel
Hi David,
Thanks for reaching. there is an same error reported before.
For Error 14566 , you can try use the following assignment. set_global_assignment -name AUTO_RESERVE_CLKUSR_FOR_CALIBRATION OFF
Detail information you may get in the KDB https://www.intel.com/content/www/us/en/support/programmable/articles/000074695.html#:~:text=%C2%AE%2010%20devices%3A-,Error%20(14566)%3A%20The%20Fitter%20cannot%20place%201%20periphery%20component,and%20then%20rerun%20the%20Fitter.
Please try it and let me know the finding,
Wincent_Intel
Hi Wincent
Thank you for your prompt response, I tried it, it didn't work.
I searched the error database; I found this link is the closest one
You may see this error when using the Arria® 10 device, Native PHY IP in PIPE mode. This is error is due to a mismatch between bonding master setting and physical transceiver channel placement.
To fix this problem modify the bonding master setting in Native PHY IP to match transceiver channel placement. The bonding master should be in physical channel CH1 or CH4. For example, if the following x4 PIPE transceiver channel placement is used, the bonding master is 1.
| Logical Channel |
Physical Channel |
| Ch0 | GXBL1C_RX_CH3 |
| Ch1 | GXBL1C_RX_CH4 |
| Ch2 | GXBL1C_RX_CH5 |
| Ch3 | GXBL1D_RX_CH0 |
but I don't fully understand what the Description and Resolution is talking about.
could you please give me more detail of the resolution. I am not very familiar with PCIe IP, I instruction how to operate.
Thank you again.
David
- Wincent_Altera3 years ago
Hi David,
The KDB provided is for Tranceiver PHY IP (Native PHY IP) , not so related to PCIe. Not sure if you had include it in your design or not.
If have, you can set it as below picture, via the PHY IP GUI.Each of our HardIPs has a dedicated perstn pin location.
PCIe IP need to assign to fix channel location, detail about the IP location you may refer to Arria 10 User Guide)
Please check and ensure that you assign correctly.
Hope this is helpful.
Wincent_Intel- dsun013 years ago
Contributor
Hi Wincent,
What is KDB stand for? how to include it in my design?
I am using standard Intel PCIe IP, here is the parameter setup interface. I couldn't see where I can setup bonding master.
I choose the parameters and generate example first, it compiled without any problem, after I intergrate to my design, the error happens. I guess there may be a resource conflict. so the assignment is the key point to solve the problem.
I also attached the QSF file of the example, it doesn't help if I copied all lines into my final project qsf file.
while I am checking how to assign the channel location. could you please give me a example of the .qsf with the channel location lock. it will make my learning process faster.
I am an old engineer, still need to learn new skill. Appreciate your help and patience.
Happy holiday.
David
Hi David,
Wincent_Intel
